24.7.2009, 18:21
#21315
На личном авто загорелась лампа airbag. Просканировал лаунчем код B1448 OC SENSOR MAT DEFECT H. Подскажите пожалуйста, что это за сенсор?
24.7.2009, 20:28
#21322
Группа: Пользователи Сообщений: 9 Спасибо сказали: 1 раз |
Hyundai - Air Bag Restraint Systems DIAGNOSTIC TROUBLE CODE IDENTIFICATION B1111 Battery voltage high B1112 Battery voltage low B1338 Front impact sensor defective B1339 Front impact sensor communication error B1346 Driver-side air bag resistance high B1347 Driver-side air bag resistance low B1348 Driver-side air bag short to ground B1349 Driver-side air bag short to battery B1352 Passenger-side air bag resistance high B1353 Passenger-side air bag resistance low B1355 Passenger-side air bag short to battery B1361 Driver seat belt pretensioner resistance high B1362 Driver seat belt pretensioner resistance low B1363 Driver seat belt pretensioner short to ground B1364 Driver seat belt pretensioner short to battery B1367 Passenger seat belt pretensioner resistance high B1368 Passenger seat belt pretensioner resistance low B1369 Passenger seat belt pretensioner short to ground B1370 Passenger seat belt pretensioner short to battery B1378 Driver side impact air bag resistance high B1379 Driver side impact air bag resistance low B1380 Driver side impact air bag short to ground B1381 Driver side impact air bag short to battery B1382 Passenger side impact air bag open B1383 Passenger side impact air bag resistance low B1384 Passenger side impact air bag short to ground B1385 Passenger side impact air bag short to battery B1387 Driver seat position sensor short to battery B1388 Driver seat position sensor short to ground B1389 Driver seat track position sensor defect B1390 Passenger seat track position sensor short to ground B1391 Passenger seat track position sensor short to battery B1392 Passenger seat track position sensor defect B1400 Driver-side satellite sensor defective B1403 Passenger-side satellite sensor defective B1409 Driver-side satellite sensor communication error B1410 Passenger-side satellite sensor communication error B1447 Occupant classification ECU defect B1448 Occupant classification sensor defect B1449 Occupant classification communication error B1450 Occupant classification wrong identification B1481 Second stage driver-side air bag resistance high B1482 Second stage driver-side air bag resistance low B1483 Second stage driver-side air bag short to ground B1484 Second stage driver-side air bag short to battery B1485 Second stage passenger-side air bag resistance high B1486 Second stage passenger-side air bag resistance low B1488 Second stage passenger-side air bag short to battery B1511 Driver seat belt switch short to battery B1512 Driver seat belt switch short to ground B1513 Passenger seat belt switch short to battery B1514 Passenger seat belt switch short to ground B1515 Driver seat belt switch defect B1516 Passenger seat belt switch defect B1620 SRSCM internal fault B1650 Front crash recorded B1651 Crash recorded driver side impact air bag B1652 Crash recorded passenger side impact air bag B1657 Belt pretensioner deployment B1670 Second stage crash recorded B2500 AIR BAG warning light failure B2502 Tell tale light failure Смотри в правом сидении |
24.7.2009, 21:18
#21331
Группа: Real User Сообщений: 508 Спасибо сказали: 21 раз |
похоже невидит датчика присутствия пассажира
25.7.2009, 14:17
#21369
Спасибо. Буду разбирать сиденье.
31.7.2009, 14:38
#21608
Разобрал сиденье, достал датчик. Фотку прилагаю. Отдельно этот датчик не продаётся только с сидушкой. Может делает кто эмуляторы? Подскажие если кто знает. На мазды видел в инете, на этот авто нет.
21.12.2009, 15:25
#29675
Приветствую, у меня такая же проблема: В1362 Driver seat belt pretensioner resistance low. Как ты с этим разобрался?
3.1.2010, 15:35
#30326
Всех С Новым Годом!!! Помогите расшифровать ошибку на такой же машинке: B1462 PPD Circuit-open.
3.1.2010, 19:24
#30335
Всех С Новым Годом!!! Помогите расшифровать ошибку на такой же машинке: B1462 PPD Circuit-open. B1462 Seat Belt Switch Circuit Failure |
3.1.2010, 22:39
#30352
![]() Группа: Пользователи Сообщений: 1 Спасибо сказали: 0 раз |
Я думаю что это Passenger Presence Detection- тоже проблема с сиденьем
8.1.2010, 13:03
#30605
Я думаю что это Passenger Presence Detection- тоже проблема с сиденьем Да именно он. Спасибо. |
13.1.2010, 10:16
#30916
Группа: Пользователи Сообщений: 36 Спасибо сказали: 0 раз |
Когда не знаеш что значит код, то просто набери этот код в googl там наверняка найдеш что он значит.
17.1.2010, 13:53
#31198
Всем привет! Кто как решил проблему с дачтиком пассажира? :(
19.3.2010, 12:35
#35140
там проводок пружинкой пережимается и рвется, перепаиваем проводое и всё ок
10.12.2025, 14:32 Посл. ответ от slalex |
Сегодня, 12:33 Посл. ответ от Алексей |
Сегодня, 8:06 Посл. ответ от LEGS |
Сегодня, 2:17 Посл. ответ от LEGS |
Вчера, 13:03 Посл. ответ от LEGS |
18.12.2025, 19:18 Посл. ответ от slalex |
| Сейчас: 21.12.2025, 19:55 |
