Hunday_Elantra_2004_USA, Не могу расшифровать код.
 boltrts
сообщение 24.7.2009, 18:21
Сообщение #21315
Спасибо сказали: 17 раз
На личном авто загорелась лампа airbag. Просканировал лаунчем код B1448 OC SENSOR MAT DEFECT H. Подскажите пожалуйста, что это за сенсор? :icon_superschnute:
Ответов (1 - 12)
 AYD
сообщение 24.7.2009, 20:28
Сообщение #21322
Hyundai - Air Bag Restraint Systems
DIAGNOSTIC TROUBLE CODE IDENTIFICATION
B1111 Battery voltage high
B1112 Battery voltage low
B1338 Front impact sensor defective
B1339 Front impact sensor communication error
B1346 Driver-side air bag resistance high
B1347 Driver-side air bag resistance low
B1348 Driver-side air bag short to ground
B1349 Driver-side air bag short to battery
B1352 Passenger-side air bag resistance high
B1353 Passenger-side air bag resistance low
B1355 Passenger-side air bag short to battery
B1361 Driver seat belt pretensioner resistance high
B1362 Driver seat belt pretensioner resistance low
B1363 Driver seat belt pretensioner short to ground
B1364 Driver seat belt pretensioner short to battery
B1367 Passenger seat belt pretensioner resistance high
B1368 Passenger seat belt pretensioner resistance low
B1369 Passenger seat belt pretensioner short to ground
B1370 Passenger seat belt pretensioner short to battery
B1378 Driver side impact air bag resistance high
B1379 Driver side impact air bag resistance low
B1380 Driver side impact air bag short to ground
B1381 Driver side impact air bag short to battery
B1382 Passenger side impact air bag open
B1383 Passenger side impact air bag resistance low
B1384 Passenger side impact air bag short to ground
B1385 Passenger side impact air bag short to battery
B1387 Driver seat position sensor short to battery
B1388 Driver seat position sensor short to ground
B1389 Driver seat track position sensor defect
B1390 Passenger seat track position sensor short to ground
B1391 Passenger seat track position sensor short to battery
B1392 Passenger seat track position sensor defect
B1400 Driver-side satellite sensor defective
B1403 Passenger-side satellite sensor defective
B1409 Driver-side satellite sensor communication error
B1410 Passenger-side satellite sensor communication error
B1447 Occupant classification ECU defect
B1448 Occupant classification sensor defect
B1449 Occupant classification communication error
B1450 Occupant classification wrong identification
B1481 Second stage driver-side air bag resistance high
B1482 Second stage driver-side air bag resistance low
B1483 Second stage driver-side air bag short to ground
B1484 Second stage driver-side air bag short to battery
B1485 Second stage passenger-side air bag resistance high
B1486 Second stage passenger-side air bag resistance low
B1488 Second stage passenger-side air bag short to battery
B1511 Driver seat belt switch short to battery
B1512 Driver seat belt switch short to ground
B1513 Passenger seat belt switch short to battery
B1514 Passenger seat belt switch short to ground
B1515 Driver seat belt switch defect
B1516 Passenger seat belt switch defect
B1620 SRSCM internal fault
B1650 Front crash recorded
B1651 Crash recorded driver side impact air bag
B1652 Crash recorded passenger side impact air bag
B1657 Belt pretensioner deployment
B1670 Second stage crash recorded
B2500 AIR BAG warning light failure
B2502 Tell tale light failure
Смотри в правом сидении
 sovig
сообщение 24.7.2009, 21:18
Сообщение #21331
Спасибо сказали: 21 раз
похоже невидит датчика присутствия пассажира
 boltrts
сообщение 25.7.2009, 14:17
Сообщение #21369
Спасибо. Буду разбирать сиденье.
 boltrts
сообщение 31.7.2009, 14:38
Сообщение #21608
Разобрал сиденье, достал датчик. Фотку прилагаю. Отдельно этот датчик не продаётся только с сидушкой. Может делает кто эмуляторы? Подскажие если кто знает. На мазды видел в инете, на этот авто нет.
Прикрепленный файл  OC_SENSOR.jpg ( 219.98 kB )
 isaak
сообщение 21.12.2009, 15:25
Сообщение #29675
Приветствую, у меня такая же проблема: В1362 Driver seat belt pretensioner resistance low. Как ты с этим разобрался?
 boltrts
сообщение 3.1.2010, 15:35
Сообщение #30326
Всех С Новым Годом!!! Помогите расшифровать ошибку на такой же машинке: B1462 PPD Circuit-open.
 Savage
сообщение 3.1.2010, 19:24
Сообщение #30335
Спасибо сказали: 6 раз
B1462 Seat Belt Switch Circuit Failure
 Virgss
сообщение 3.1.2010, 22:39
Сообщение #30352
Я думаю что это Passenger Presence Detection- тоже проблема с сиденьем
 boltrts
сообщение 8.1.2010, 13:03
Сообщение #30605
Да именно он. Спасибо.
 pavelll
сообщение 13.1.2010, 10:16
Сообщение #30916
Когда не знаеш что значит код, то просто набери этот код в googl там наверняка найдеш что он значит.
 Gromka
сообщение 17.1.2010, 13:53
Сообщение #31198
Всем привет! Кто как решил проблему с дачтиком пассажира? :(
 c40vd63001
сообщение 19.3.2010, 12:35
Сообщение #35140
там проводок пружинкой пережимается и рвется, перепаиваем проводое и всё ок
  Сейчас: 18.10.2026, 18:24
