28.2.2011, 1:41
#52101
Группа: Участник Сообщений: 24 Спасибо сказали: 0 раз |
Hello somebody now how to change km in this dashbord, i try with taho universal but no working with diagnostic cluster.
28.2.2011, 1:56
#52103
Группа: Real User Сообщений: 92 Спасибо сказали: 4 раза |
Hello somebody now how to change km in this dashbord, i try with taho universal but no working with diagnostic cluster. Hi! Mileage in this car is not in the dashboard, and is in the BSI is MCU motorolla 68HC11K4! Read and counted and recorded! |
28.2.2011, 3:27
#52112
Hello somebody now how to change km in this dashbord, i try with taho universal but no working with diagnostic cluster. It works, tested. Need to use CAN dongl... IGN turn on-off or position 1 and door open. After the procedure to remove battery terminal. |
28.2.2011, 21:01
#52153
wich you meen can dong ?, i have 2 cables for chrysler, both try but no one working.
Отредактированно gedas8899 - 28.2.2011, 21:03
1.3.2011, 0:26
#52172
wich you meen can dong ?, i have 2 cables for chrysler, both try but no one working. CDI => DASH, SRI => ECU. To avoid damage to disconnect the CAN adapter only OBDII connector of the car! |
3.3.2011, 21:48
#52350
Sorry for stupid question, whic of thouse cables i need to use?
Отредактированно gedas8899 - 3.3.2011, 21:55
26.11.2014, 7:30
#93108
you commented that you can do with the tacho 2008 very easy with the cable 35 with the door open and put only
CHRYSLER -> VOYAGER -> ´02 DIAGNOSIS t is very easy and if you need the connection of the micro warns me and get on the forum regards I hope you work |
| Сейчас: 28.6.2026, 12:29 |
