8.2.2012, 16:14
#62614
Группа: Участник Сообщений: 157 Спасибо сказали: 7 раз |
Здравствуйте!
Может у кого есть флеш BMW E90 CAS 3 XDP512,обязательно с ELV!Пусть будет от 71,70........ Отредактированно Darck - 10.7.2016, 10:46
15.3.2012, 4:23
#63689
you can try to update flash using WINKFP .
winkfp can reprogramm flash without ignition and without key in ignitioon. but you need to know the ZB code of the software in the car, so that you can choose the ZB number to write with WINKFPT. if damaged flash, no ignition, cant find the ZB with progman. before any operation to CAS, read the ZB to know what software is into the car... |
10.7.2016, 4:17
#230082
you can try to update flash using WINKFP . winkfp can reprogramm flash without ignition and without key in ignitioon. but you need to know the ZB code of the software in the car, so that you can choose the ZB number to write with WINKFPT. if damaged flash, no ignition, cant find the ZB with progman. before any operation to CAS, read the ZB to know what software is into the car... How to read zb? What software. Thanks |
10.7.2016, 9:28
#230087
Сегодня, 0:12 Посл. ответ от Egorich |
Вчера, 18:19 Посл. ответ от dhia |
| Сейчас: 11.10.2026, 14:13 |
