3.2.2009, 18:00
#10773
Please help me ,I try with immo killer but car only start one times and after than no start,I try with renault ECU decoding and after 6hours and immo emulator nothing,this is dump from 95080, if anyone have solution email me
1.2.2011, 6:02
#50743
Please help me ,I try with immo killer but car only start one times and after than no start,I try with renault ECU decoding and after 6hours and immo emulator nothing,this is dump from 95080, if anyone have solution email me onli inmokiller sofware |
8.2.2011, 21:00
#51089
You can use write protect of the IC. Can be done with proper programmer (write protect) or on hardware way (lift pin7 and connect pin8). Like that car will crank every time. Also if you in possession of the key just re solder all components except Megamos.
9.2.2011, 9:13
#51101
Also if you are in deep shit (problem) you can just remove 95080 but as results no acceleration and no heating elements (problem with cold start). I am using that when I have to move car to the my garage.
| Сейчас: 15.11.2026, 3:35 |
