25.8.2011, 23:15
#58072
![]() Группа: Пользователи Сообщений: 2 Спасибо сказали: 0 раз |
Hello,
my name is Goofy and i'm new here. But i hope you can help me. If this Post is in the wrong section - please move it to the right ;) So, now to my problem - i need to reset a BMW EWS3 Module. I tryed it with the BMW Scanner 1.4.0.8 but without success. i read in the Internet, i must solder a connection at the Square processor, but if i do this, the EWS3 Module doesn't response to the Software. If i do not solder the connection, i can read out the data .... then if i want to erase the module the programm says connect PIN4 and PIN 8 (EWS3) then erase and afer this cut the connection ... but if i connect these pins i get no response too ?? Have anybody a idea ? Or can tell me, what is my misstake ? Goofy PS: in the next days i will become a CAS3 Programmer and then i can read out the Data as a bin file. can anybody tell me a programm to erase the EWS3 with a bin file ? |
29.8.2011, 15:06
#58134
Can nobody help me ?
Now i'm have a Editor, with i can open EWS in files ..... but now i need a sample ? And i can't download from the CarDamp Base :( Goofy |
17.1.2012, 18:50
#61852
Can nobody help me ? Now i'm have a Editor, with i can open EWS in files ..... but now i need a sample ? And i can't download from the CarDamp Base :( Goofy Hi, did you found some solutions? i'm quite interested by, i have the same problem. moreover i made an mistake in pa soft, checking in coding the ews3 algorithm instead of "as ews2" and now i cannot reverse and communicate with ews. i made the same tests you described and had the same disappointments. regards chris -------------------- Christophe
Вчера, 14:36 Посл. ответ от karel_new |
| Сейчас: 21.11.2026, 3:33 |
