Ошибка в UPA-USB
1 из 3>»
 halyava
сообщение 27.5.2008, 23:24
Сообщение #2668
есть такая проблемка, при подключении программатора в логе пишет
USB Module Connected
Programmer not Found 1001
при проведении теста tools/hardwaretest выскакивает ошибка, после этого в логе пишет
Programmer not Recognized
лог теста:
5V Tests. Close J1 and press a key to continue
Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=0,95V (H), P3=0,00V (L), P4=0,00V (L),P6=0,95V (H), P7=0,00V (L), P8=0,00V (L), P9=1,08V
P2(0,95V ) not in 0,00V - 0,25V
P6(0,95V ) not in 0,00V - 0,25V
P9(1,08V ) not in 0,00V - 0,25V
Test Failed
Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=8,06V, P2=0,40V (L), P3=0,00V (L), P4=0,00V (L),P6=0,40V (L), P7=0,00V (L), P8=0,00V (L), P9=0,45V
P2(0,40V ) not in 0,00V - 0,25V
P6(0,40V ) not in 0,00V - 0,25V
P9(0,45V ) not in 0,00V - 0,25V
Test Failed
Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,14V, P2=0,26V (L), P3=0,00V (L), P4=0,00V (L),P6=0,26V (L), P7=0,00V (L), P8=0,00V (L), P9=0,29V
P2(0,26V ) not in 0,00V - 0,25V
P6(0,26V ) not in 0,00V - 0,25V
P9(0,29V ) not in 0,00V - 0,25V
Test Failed
Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,02V, P2=0,16V (L), P3=0,00V (L), P4=0,00V (L),P6=0,16V (L), P7=0,00V (L), P8=0,00V (L), P9=0,19V
Test Passed
Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,92V, P2=0,11V (L), P3=0,00V (L), P4=0,00V (L),P6=0,11V (L), P7=0,00V (L), P8=0,00V (L), P9=0,11V
Test Passed
Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=12,02V, P2=0,06V (L), P3=0,00V (L), P4=0,00V (L),P6=0,06V (L), P7=0,00V (L), P8=0,05V (L), P9=0,08V
Test Passed
Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=12,92V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,10V (L), P9=0,05V
Test Passed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=3,61V (L), P3=0,00V (L), P4=0,00V (L),P6=3,64V (L), P7=0,00V (L), P8=0,06V (L), P9=4,77V
Test Passed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,06V (L), P3=0,00V (L), P4=0,00V (L),P6=0,06V (L), P7=0,00V (L), P8=0,00V (L), P9=4,77V
Test Passed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,72V (H), P3=4,72V (H), P4=4,71V (H),P6=4,72V (H), P7=4,71V (H), P8=4,72V (H), P9=4,75V
Test Passed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=2,93V (H), P3=0,00V (H), P4=0,03V (H),P6=2,93V (H), P7=0,00V (H), P8=0,05V (H), P9=3,43V
Test Passed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=3,42V
Test Passed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=3,45V (H), P3=3,43V (H), P4=3,43V (H),P6=3,43V (H), P7=3,43V (H), P8=3,43V (H), P9=3,42V
Test Passed
Test60
9000000064ED8C65
Test Failed
4 Tests failed
кто знает в чем проблема???
сообщение 27.5.2008, 23:56
Сообщение #2670
Спасибо сказали: 2063 раза
Результат теста отправим в тех поддержку.
 RAF
сообщение 29.5.2008, 5:10
Сообщение #2694
Было такое. Отправлял программатор на ремонт по гарантии продавцу.
 halyava
сообщение 30.5.2008, 17:55
Сообщение #2706
спасибо
 vladimir_vl
сообщение 4.6.2008, 11:50
Сообщение #2782
Спасибо сказали: 6 раз
лог теста:
Test Failed
Test Failed
Test Failed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test Passed
Test60
9000000064ED8C65
Test Failed
4 Tests failed
прогер чувствителен к шнуру USB, лучше использовать толстый шнур от принтера
сообщение 4.6.2008, 11:56
Сообщение #2784
Это мы уже рассматривали, но дело в том, что сам адаптер USB определяется без ошибки в Windows, а когда шнурок плохой, то в строке состояния справа выскакивает желтое сообщение, что оборудование может работать не правильно.
 Valera-02
сообщение 10.6.2008, 10:06
Сообщение #2912
Что-то подобное было у меня. Отправил лог автору, он присоветовал поменять плавкий предохранитель (похож на транзистор 3102, только на двух ногах). Заменил - заработало
сообщение 10.6.2008, 16:26
Сообщение #2921
Также он советовал, но предохранитель был хороший, и в итоге прислали какой-то patch и все заработало, со слов halyava.
 alexG
сообщение 29.5.2009, 6:18
Сообщение #18750
Тема закрыта.
Dergite komu nado patch Fix. Esli problemi s progerom.
Прикрепленный файл  uusp_patch_fix.rar ( 312.78 kB )
Отредактированно alexG - 29.5.2009, 6:19
 serg_tuning
сообщение 22.6.2010, 23:53
Сообщение #40676
Группа: Заблокированные
У меня появилась вот такая проблема-что можно сделать?
Result: P1=2,00V, P2=2,00V (L), P3=1,98V (L), P4=1,97V (L),P6=1,98V (L), P7=2,00V (L), P8=1,97V (L), P9=2,00V
P1(2,00V ) not in 0,00V - 0,25V
P2(2,00V ) not in 0,00V - 0,25V
P3(1,98V ) not in 0,00V - 0,25V
P4(1,97V ) not in 0,00V - 0,25V
P6(1,98V ) not in 0,00V - 0,25V
P7(2,00V ) not in 0,00V - 0,25V
P8(1,97V ) not in 0,00V - 0,25V
P9(2,00V ) not in 0,00V - 0,25V
Test Failed
Result: P1=12,44V, P2=4,72V (L), P3=4,48V (L), P4=6,51V (L),P6=4,67V (L), P7=4,48V (L), P8=5,98V (L), P9=4,69V
P1(12,44V ) not in 7,70V - 8,30V
P2(4,72V ) not in 0,00V - 0,25V
P3(4,48V ) not in 0,00V - 0,25V
P4(6,51V ) not in 0,00V - 0,25V
P6(4,67V ) not in 0,00V - 0,25V
P7(4,48V ) not in 0,00V - 0,25V
P8(5,98V ) not in 0,00V - 0,25V
P9(4,69V ) not in 0,00V - 0,25V
Test Failed
Result: P1=13,81V, P2=7,64V (L), P3=7,25V (L), P4=7,77V (L),P6=7,28V (L), P7=9,54V (L), P8=7,07V (L), P9=8,77V
P1(13,81V ) not in 8,70V - 9,30V
P2(7,64V ) not in 0,00V - 0,25V
P3(7,25V ) not in 0,00V - 0,25V
P4(7,77V ) not in 0,00V - 0,25V
P6(7,28V ) not in 0,00V - 0,25V
P7(9,54V ) not in 0,00V - 0,25V
P8(7,07V ) not in 0,00V - 0,25V
P9(8,77V ) not in 0,00V - 0,25V
Test Failed
Result: P1=13,97V, P2=9,39V (L), P3=9,68V (L), P4=8,67V (L),P6=10,09V (L), P7=8,83V (L), P8=9,02V (L), P9=8,88V
P1(13,97V ) not in 9,70V - 10,30V
P2(9,39V ) not in 0,00V - 0,25V
P3(9,68V ) not in 0,00V - 0,25V
P4(8,67V ) not in 0,00V - 0,25V
P6(10,09V ) not in 0,00V - 0,25V
P7(8,83V ) not in 0,00V - 0,25V
P8(9,02V ) not in 0,00V - 0,25V
P9(8,88V ) not in 0,00V - 0,25V
Test Failed
Result: P1=14,63V, P2=10,17V (L), P3=10,76V (L), P4=9,67V (L),P6=10,28V (L), P7=9,85V (L), P8=9,97V (L), P9=10,73V
P1(14,63V ) not in 10,70V - 11,30V
P2(10,17V ) not in 0,00V - 0,25V
P3(10,76V ) not in 0,00V - 0,25V
P4(9,67V ) not in 0,00V - 0,25V
P6(10,28V ) not in 0,00V - 0,25V
P7(9,85V ) not in 0,00V - 0,25V
P8(9,97V ) not in 0,00V - 0,25V
P9(10,73V ) not in 0,00V - 0,25V
Test Failed
Result: P1=15,45V, P2=10,99V (L), P3=11,36V (L), P4=10,54V (L),P6=10,86V (L), P7=10,59V (L), P8=11,39V (L), P9=10,57V
P1(15,45V ) not in 11,70V - 12,30V
P2(10,99V ) not in 0,00V - 0,25V
P3(11,36V ) not in 0,00V - 0,25V
P4(10,54V ) not in 0,00V - 0,25V
P6(10,86V ) not in 0,00V - 0,25V
P7(10,59V ) not in 0,00V - 0,25V
P8(11,39V ) not in 0,00V - 0,25V
P9(10,57V ) not in 0,00V - 0,25V
Test Failed
Result: P1=16,08V, P2=11,09V (L), P3=10,88V (L), P4=11,54V (L),P6=11,26V (L), P7=11,12V (L), P8=11,13V (L), P9=10,84V
P1(16,08V ) not in 12,70V - 13,30V
P2(11,09V ) not in 0,00V - 0,25V
P3(10,88V ) not in 0,00V - 0,25V
P4(11,54V ) not in 0,00V - 0,25V
P6(11,26V ) not in 0,00V - 0,25V
P7(11,12V ) not in 0,00V - 0,25V
P8(11,13V ) not in 0,00V - 0,25V
P9(10,84V ) not in 0,00V - 0,25V
Test Failed
Result: P1=3,63V, P2=9,73V (L), P3=3,50V (L), P4=3,46V (L),P6=9,68V (L), P7=6,09V (L), P8=3,88V (L), P9=10,12V
P1(3,63V ) not in 0,00V - 0,25V
P2(9,73V ) not in 3,00V - 4,00V
P3(3,50V ) not in 0,00V - 0,25V
P4(3,46V ) not in 0,00V - 0,25V
P6(9,68V ) not in 3,00V - 4,00V
P7(6,09V ) not in 0,00V - 0,25V
P8(3,88V ) not in 0,00V - 0,25V
P9(10,12V ) not in 4,40V - 5,25V
Test Failed
Result: P1=2,92V, P2=2,96V (L), P3=2,88V (L), P4=2,87V (L),P6=2,95V (L), P7=2,90V (L), P8=2,87V (L), P9=9,38V
P1(2,92V ) not in 0,00V - 0,25V
P2(2,96V ) not in 0,00V - 0,25V
P3(2,88V ) not in 0,00V - 0,25V
P4(2,87V ) not in 0,00V - 0,25V
P6(2,95V ) not in 0,00V - 0,25V
P7(2,90V ) not in 0,00V - 0,25V
P8(2,87V ) not in 0,00V - 0,25V
P9(9,38V ) not in 4,40V - 5,25V
Test Failed
Result: P1=2,88V, P2=9,36V (H), P3=9,36V (H), P4=9,33V (H),P6=9,35V (H), P7=9,35V (H), P8=9,33V (H), P9=9,33V
P1(2,88V ) not in 0,00V - 0,25V
P2(9,36V ) not in 4,00V - 5,25V
P3(9,36V ) not in 4,00V - 5,25V
P4(9,33V ) not in 4,00V - 5,25V
P6(9,35V ) not in 4,00V - 5,25V
P7(9,35V ) not in 4,00V - 5,25V
P8(9,33V ) not in 4,00V - 5,25V
P9(9,33V ) not in 4,40V - 5,25V
Test Failed
Result: P1=2,72V, P2=8,54V (H), P3=2,72V (H), P4=2,71V (H),P6=8,54V (H), P7=2,74V (H), P8=2,69V (H), P9=9,06V
P1(2,72V ) not in 0,00V - 0,25V
P2(8,54V ) not in 2,50V - 3,30V
P3(2,72V ) not in 0,00V - 0,25V
P4(2,71V ) not in 0,00V - 0,25V
P6(8,54V ) not in 2,50V - 3,30V
P7(2,74V ) not in 0,00V - 0,25V
P8(2,69V ) not in 0,00V - 0,25V
P9(9,06V ) not in 3,00V - 3,70V
Test Failed
Result: P1=2,93V, P2=2,98V (L), P3=2,92V (L), P4=2,90V (L),P6=2,96V (L), P7=2,92V (L), P8=2,87V (L), P9=9,39V
P1(2,93V ) not in 0,00V - 0,25V
P2(2,98V ) not in 0,00V - 0,25V
P3(2,92V ) not in 0,00V - 0,25V
P4(2,90V ) not in 0,00V - 0,25V
P6(2,96V ) not in 0,00V - 0,25V
P7(2,92V ) not in 0,00V - 0,25V
P9(9,39V ) not in 3,00V - 3,70V
Test Failed
Result: P1=2,79V, P2=9,17V (H), P3=9,18V (H), P4=9,15V (H),P6=9,17V (H), P7=9,18V (H), P8=9,14V (H), P9=9,15V
P1(2,79V ) not in 0,00V - 0,25V
P2(9,17V ) not in 3,00V - 3,70V
P3(9,18V ) not in 3,00V - 3,70V
P4(9,15V ) not in 3,00V - 3,70V
P6(9,17V ) not in 3,00V - 3,70V
P7(9,18V ) not in 3,00V - 3,70V
P8(9,14V ) not in 3,00V - 3,70V
P9(9,15V ) not in 3,00V - 3,70V
Test Failed
Test60
958A89E26EB120A2
Test Passed
13 Tests failed
Патсч что то не помог
Отредактированно serg_tuning - 22.6.2010, 23:55
 serg_tuning
сообщение 23.6.2010, 8:50
Сообщение #40684
Заменил еще пред похожий на 3102 и вот что получилось
Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Result: P1=6,85V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(6,85V ) not in 7,70V - 8,30V
Test Failed
Result: P1=7,81V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(7,81V ) not in 8,70V - 9,30V
Test Failed
Result: P1=8,62V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(8,62V ) not in 9,70V - 10,30V
Test Failed
Result: P1=9,38V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(9,38V ) not in 10,70V - 11,30V
Test Failed
Result: P1=10,34V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(10,34V ) not in 11,70V - 12,30V
Test Failed
Result: P1=11,13V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(11,13V ) not in 12,70V - 13,30V
Test Failed
Result: P1=0,00V, P2=3,82V (L), P3=0,00V (L), P4=0,00V (L),P6=3,82V (L), P7=0,00V (L), P8=0,00V (L), P9=5,03V
Test Passed
Result: P1=0,00V, P2=0,06V (L), P3=0,00V (L), P4=0,00V (L),P6=0,06V (L), P7=0,00V (L), P8=0,00V (L), P9=5,03V
Test Passed
Result: P1=0,00V, P2=4,93V (H), P3=4,93V (H), P4=4,93V (H),P6=4,95V (H), P7=4,93V (H), P8=4,91V (H), P9=5,03V
Test Passed
Result: P1=0,00V, P2=3,14V (H), P3=0,00V (H), P4=0,00V (H),P6=3,14V (H), P7=0,00V (H), P8=0,00V (H), P9=3,66V
Test Passed
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=3,64V
Test Passed
Result: P1=0,00V, P2=3,67V (H), P3=3,67V (H), P4=3,66V (H),P6=3,67V (H), P7=3,67V (H), P8=3,66V (H), P9=3,64V
Test Passed
Test60
958A89E26EB120A2
Test Passed
6 Tests failed
 k-koloya
сообщение 31.1.2011, 14:41
Сообщение #50722
Спасибо сказали: 78 раз
отличный патч, меня просто выручил, я уже почти новую юпу заказал....спасибо огромнейшее. где ты его кстати взял?
 gaws
сообщение 31.1.2011, 19:52
Сообщение #50729
Патч выдает автор упы по запросу
 budjoni
сообщение 11.11.2013, 0:50
Сообщение #73794
NI5U заменить резистор 000 и мой UUSP1 готов к работе!
 ester
сообщение 27.1.2014, 18:38
Сообщение #77006
патч на номер прогера 05B2ED32, помочь не может, активация не проходит
1 из 3>»
23 чел. читают эту тему (гостей: 23, скрытых пользователей: 0)
  Сейчас: 10.7.2026, 4:03
