Flash CAS2 BMW 118D E87
 bilchip
сообщение 4.3.2014, 1:11
Сообщение #78997
Hello
I search flash for programming CAS2
nummer : 6135 - 69433791
please because I am new with forum and no possible download flash with CARDAMP.RU
my adress mail : autokm1@hotmail.com
please send me flash for my cas
it is very important for me
thank you very much
сообщение 4.3.2014, 2:02
Сообщение #78999
Спасибо сказали: 2063 раза
Downloading files from CARDAMP.RU only paid.
Registration in CarDamp
Enter when registering your Login and email from the forum.
 bilchip
сообщение 6.3.2014, 1:08
Сообщение #79084
hello
I download programm FLASH and eeprom for BMW E87 cas 6135-6943791 but your file is .bin and me I need file .0pa
I would like program my cas with abritus avdi and file is not correct because it's .bin
possible help me please
thanks
сообщение 6.3.2014, 1:14
Сообщение #79085
Files in the database only .bin!
You need to write a file in a normal programmer, for example XProg-M and others.
сообщение 6.3.2014, 1:22
Сообщение #79086
Files in the database explicitly, not encrypted. If abritus not encrypt files, then just change the extension from .bin to .0pa.
 bilchip
сообщение 6.3.2014, 1:25
Сообщение #79087
thank you
change the extension from bin to 0pa. but no good and I have another files receive with abritus but nummer for my cas not correct and I write but signature not correct, I absolute need files with exactly nummer .0pa
I try change extension but no good
I am forced to desoldering motorolla MC9S12?
If I write the new file, y' will have an immobilizer problem?
if you have another solution for no desoldering its perfect for me
 bilchip
сообщение 6.3.2014, 1:28
Сообщение #79088
http://update2.abritus72.net/downloads/flashdb/
all files for module UNIT BMW
you possible download and see extension is 0pa
GRATIS FOR YOU
сообщение 6.3.2014, 1:29
Сообщение #79089
Yes
Yes
What's wrong with your module CAS? Why do you change the flash?
 bilchip
сообщение 6.3.2014, 1:32
Сообщение #79090
I program key and I erase program remote control for my key
I have 2 key, my bmw start but I dont have remote control lock and unlock for my key
but before my key for remote contrôleis correct
and I would like test flash my CAS
сообщение 6.3.2014, 1:46
Сообщение #79091
It will not work. There is a problem immobilizer and radio channel keychain ...
On your link is no such module in Abritus? If it is there, it will not help you.
 bilchip
сообщение 6.3.2014, 1:52
Сообщение #79092
ok IF I write flash for 6135-6943797, NO PROBLEM??? because my cas is 6135-6943791
сообщение 6.3.2014, 1:55
Сообщение #79093
GRATIS FOR YOU
Useless data :)
I do not know, but you have to reprogram the keys.
  Сейчас: 28.6.2026, 16:44
