4.3.2014, 1:11
#78997
Hello
I search flash for programming CAS2 nummer : 6135 - 69433791 please because I am new with forum and no possible download flash with CARDAMP.RU my adress mail : autokm1@hotmail.com please send me flash for my cas it is very important for me thank you very much |
4.3.2014, 2:02
#78999
Downloading files from CARDAMP.RU only paid.
Registration in CarDamp Enter when registering your Login and email from the forum. |
6.3.2014, 1:08
#79084
hello
I download programm FLASH and eeprom for BMW E87 cas 6135-6943791 but your file is .bin and me I need file .0pa I would like program my cas with abritus avdi and file is not correct because it's .bin possible help me please thanks |
6.3.2014, 1:14
#79085
Files in the database only .bin!
You need to write a file in a normal programmer, for example XProg-M and others. |
6.3.2014, 1:22
#79086
Files in the database explicitly, not encrypted. If abritus not encrypt files, then just change the extension from .bin to .0pa.
6.3.2014, 1:25
#79087
thank you
change the extension from bin to 0pa. but no good and I have another files receive with abritus but nummer for my cas not correct and I write but signature not correct, I absolute need files with exactly nummer .0pa I try change extension but no good I am forced to desoldering motorolla MC9S12? If I write the new file, y' will have an immobilizer problem? if you have another solution for no desoldering its perfect for me |
6.3.2014, 1:28
#79088
http://update2.abritus72.net/downloads/flashdb/
all files for module UNIT BMW you possible download and see extension is 0pa GRATIS FOR YOU |
6.3.2014, 1:29
#79089
I am forced to desoldering motorolla MC9S12? Yes If I write the new file, y' will have an immobilizer problem? Yes What's wrong with your module CAS? Why do you change the flash? |
6.3.2014, 1:32
#79090
I program key and I erase program remote control for my key
I have 2 key, my bmw start but I dont have remote control lock and unlock for my key but before my key for remote contrôleis correct and I would like test flash my CAS |
6.3.2014, 1:46
#79091
and I would like test flash my CAS It will not work. There is a problem immobilizer and radio channel keychain ... all files for module UNIT BMW you possible download and see extension is 0pa On your link is no such module in Abritus? If it is there, it will not help you. |
6.3.2014, 1:52
#79092
ok IF I write flash for 6135-6943797, NO PROBLEM??? because my cas is 6135-6943791
6.3.2014, 1:55
#79093
all files for module UNIT BMW you possible download and see extension is 0pa GRATIS FOR YOU Useless data :) ok IF I write flash for 6135-6943797, NO PROBLEM??? because my cas is 6135-6943791 I do not know, but you have to reprogram the keys. |
Вчера, 13:11 Посл. ответ от Дмитрий |
10.9.2026, 20:52 Посл. ответ от angelferrum |
| Сейчас: 12.9.2026, 16:50 |
