CLK W209 270CDI Tacho dump 24u17
 Tachopad
сообщение 15.4.2014, 9:39
Сообщение #82088
Hello,
I need dump from eeprom 24u17/24c17 on MB CLK 270CDI w209 as original has been lost.
Tacho:
VDO 110.080.140/020
MB A 209 540 42 11
I tried this one but it is not perfect, has some minor bugs (it looks like it wasnt read 100%)
http://cardamp.ru/view_full_one.php?langs_us=en&selectserach=24109&id_damp_list=21322
Прикрепленный файл  2014-04-12_13.53.12.jpg ( 266.68 kB )
Ответов (1 - 9)
 Doctortehno
сообщение 15.4.2014, 11:17
Сообщение #82090
Master
Спасибо сказали: 421 раз
You will have mistakes with another dampy, instead of run there will be crossed out sections! It is necessary to make the dashboard new and to tie to the car diagnostics!
 Tachopad
сообщение 15.4.2014, 12:11
Сообщение #82099
What do you mean by making dashboard new? I also tried this file http://cardamp.ru/view_full_one.php?langs_us=en&selectserach=10&id_damp_list=17781
Works OK but also has bugs, for example I cannot reset service interval or calibrate fuel consumption MENU with DAS Xentry...
I also forgot to menition that I have original EEPROM read and was read out as 24c16 with UPA, size is OK and odometer value can also be seen in the file, but guess I made mistake while I read it as 24C16 and not as 24C17. As far as I know 24C16 = 24C17, just that C17 has write protection ...
Отредактированно Tachopad - 15.4.2014, 12:19
 Doctortehno
сообщение 15.4.2014, 12:49
Сообщение #82104
Master
There is nothing terrible that you read as 24с16, I always read UPA 24c17 as 24с16. There is there no protection against record!
сообщение 15.4.2014, 12:58
Сообщение #82105
Спасибо сказали: 2066 раз
File 100% great!
This is a Mercedes and not a Toyota.
Easy replacement of the dump is not suitable in this case..
Requires adaptation panel. VIN number and more...
 Tachopad
сообщение 15.4.2014, 13:34
Сообщение #82108
This is file I read with UPA as 24C16. I also read it with another programmer before trying to write to Eprom and it is same file so file is 100% original. But I cannot get tacho to work with this file, no way.
File rar deleted
 Tachopad
сообщение 15.4.2014, 13:51
Сообщение #82110
Цитата(Saveliy @ 15.4.2014, 10:58) *
File 100% great!
This is IK runing with file from dumpbase, you can see that is not 100% great as hardware number cannot be seen. Inital startup with Xentry can be completed but fuel and temp guages not work. With file I read with UPA fuel & temp guage works.
Прикрепленный файл  2014-04-15_08.55.12.jpg ( 283.55 kB )
Отредактированно Tachopad - 15.4.2014, 13:54
сообщение 15.4.2014, 15:09
Сообщение #82116
Rar files are forbidden to download!
Only .bin
сообщение 15.4.2014, 15:19
Сообщение #82117
I will tell the seller. But one and the same room does not mean that it is interchangeable. Flash (update) and the version of the file will be another.
Same thing with the EZS. The same number of the castle, but in different flash!
 Tachopad
сообщение 15.4.2014, 16:03
Сообщение #82120
Only .bin
Yes I know that different flash can affect file, but at least hardware number could be seen. So please if you can, contact the seller to read and upload file again.
Прикрепленный файл  W209_VDO_24U17.bin ( 2 kB )
  Сейчас: 22.11.2026, 17:02
