Lancia thesis
 tomo776
сообщение 26.6.2014, 12:24
Сообщение #85944
Hi
I have problem vith this dash from lancia thesis i try to change km in dash and now got eol error
No dash is : 51732540
I read with upa usb eeprom L56R and save org shange km put back and got error.
Now when i put old dumo same.
I need org dump from this dash
lancia is 2003 year.
THANX advance
Regards Tomo
I find dump on cardamp.ru but i can not download
Отредактированно tomo776 - 26.6.2014, 12:25
1 из 3>»
 Zmeiarm
сообщение 26.6.2014, 13:21
Сообщение #85950
Любопытный
Спасибо сказали: 1242 раза
u must pay for dump, this is not expensive. u must prepaid in your account some manye and after this u can download
 tomo776
сообщение 26.6.2014, 13:34
Сообщение #85951
Ok thanx
Is it km just in dash or i need ro change in ecu also?
Thanx
Отредактированно tomo776 - 26.6.2014, 13:36
 Easy
сообщение 26.6.2014, 14:08
Сообщение #85952
Спасибо сказали: 546 раз
Цитата(tomo776 @ 26.6.2014, 14:34) *
Ok thanx
Thanx
You should only do dash
 tomo776
сообщение 26.6.2014, 14:31
Сообщение #85953
But when i connect dash on desk km its ok show km on dash
But when i connect dash on car i have error
I dont understand why and i think that is only
I try now in ecu also and see what whil show
 Easy
сообщение 26.6.2014, 15:27
Сообщение #85958
And when you connect a dash on the table, you see that run that put you?
 tomo776
сообщение 26.6.2014, 17:07
Сообщение #85968
I change in ecu km and the same.
Again error.
Here is my dump from dash if someone verify that its ok.
Thanx for answer
Прикрепленный файл  org_93c56.bin ( 256 B )
 Zmeiarm
сообщение 26.6.2014, 17:26
Сообщение #85971
Любопытный
238496km ?
 tomo776
сообщение 26.6.2014, 17:47
Сообщение #85975
No car have 1192xx But on dash dond work any gauge fo fuel rpm.
I dont have any idea what can be so i need org dump for compare.
I think that i need to read like 93S56 not like i did C56.
But i dont know why when i put that orgh file is the same gauge not work and on displey EOL Error.
Do any have some idea what should i do.
THANX
 Easy
сообщение 26.6.2014, 17:55
Сообщение #85977
THANX
You read like 93c56 or 93c56 * 16?
 tomo776
сообщение 26.6.2014, 17:58
Сообщение #85978
I read like c56
Upa read same c56 or c56x16.
I have upa usb v1.1
Отредактированно tomo776 - 26.6.2014, 18:00
 Easy
сообщение 26.6.2014, 18:08
Сообщение #85979
Цитата(tomo776 @ 26.6.2014, 18:58) *
I read like c56
I have upa usb v1.1
you have to do swap dumpa.
 tomo776
сообщение 26.6.2014, 18:19
Сообщение #85982
Ok i try now and report.
 tomo776
сообщение 26.6.2014, 20:06
Сообщение #85988
With this file gauge work but again error
I need oround 550 000 km if you can make this to work
Thanx
Прикрепленный файл  93C56_x16_gauge_work_but_error.bin ( 256 B )
 Voron2033
сообщение 26.6.2014, 20:31
Сообщение #85989
Спасибо сказали: 29 раз
you incorrectly read a memory chip.
 Voron2033
сообщение 26.6.2014, 20:39
Сообщение #85990
you need to look for the correct file only. To write down as 93S56.93C56 93S56 are read with honors
1 из 3>»
Чем можно зделать ?
Вчера, 21:15
Посл. ответ от slalex
19.9.2026, 15:16
Посл. ответ от Денис
замена - аналоги , информация
17.9.2026, 20:45
Посл. ответ от LEGS
16.9.2026, 19:59
Посл. ответ от Александр
16.9.2026, 11:32
Посл. ответ от Amir
  Сейчас: 23.9.2026, 21:08
