26.6.2014, 12:24
#85944
Группа: Пользователи Сообщений: 21 Спасибо сказали: 1 раз |
Hi
I have problem vith this dash from lancia thesis i try to change km in dash and now got eol error No dash is : 51732540 I read with upa usb eeprom L56R and save org shange km put back and got error. Now when i put old dumo same. I need org dump from this dash lancia is 2003 year. THANX advance Regards Tomo I find dump on cardamp.ru but i can not download Отредактированно tomo776 - 26.6.2014, 12:25
1 из 3»
26.6.2014, 13:21
#85950
u must pay for dump, this is not expensive. u must prepaid in your account some manye and after this u can download
26.6.2014, 13:34
#85951
Ok thanx
Is it km just in dash or i need ro change in ecu also? Thanx Отредактированно tomo776 - 26.6.2014, 13:36
26.6.2014, 14:08
#85952
Ok thanx Is it km just in dash or i need ro change in ecu also? Thanx You should only do dash |
26.6.2014, 14:31
#85953
But when i connect dash on desk km its ok show km on dash
But when i connect dash on car i have error I dont understand why and i think that is only I try now in ecu also and see what whil show |
26.6.2014, 15:27
#85958
But when i connect dash on desk km its ok show km on dash But when i connect dash on car i have error I dont understand why and i think that is only I try now in ecu also and see what whil show And when you connect a dash on the table, you see that run that put you? |
26.6.2014, 17:07
#85968
I change in ecu km and the same.
Again error. Here is my dump from dash if someone verify that its ok. Thanx for answer Прикрепленные файлы
26.6.2014, 17:26
#85971
238496km ?
26.6.2014, 17:47
#85975
No car have 1192xx But on dash dond work any gauge fo fuel rpm.
I dont have any idea what can be so i need org dump for compare. I think that i need to read like 93S56 not like i did C56. But i dont know why when i put that orgh file is the same gauge not work and on displey EOL Error. Do any have some idea what should i do. THANX |
26.6.2014, 17:55
#85977
No car have 1192xx But on dash dond work any gauge fo fuel rpm. I dont have any idea what can be so i need org dump for compare. I think that i need to read like 93S56 not like i did C56. But i dont know why when i put that orgh file is the same gauge not work and on displey EOL Error. Do any have some idea what should i do. THANX You read like 93c56 or 93c56 * 16? |
26.6.2014, 17:58
#85978
I read like c56
Upa read same c56 or c56x16. I have upa usb v1.1 Отредактированно tomo776 - 26.6.2014, 18:00
26.6.2014, 18:08
#85979
I read like c56 Upa read same c56 or c56x16. I have upa usb v1.1 you have to do swap dumpa. |
26.6.2014, 18:19
#85982
Ok i try now and report.
26.6.2014, 20:06
#85988
With this file gauge work but again error
I need oround 550 000 km if you can make this to work Thanx Прикрепленные файлы
26.6.2014, 20:31
#85989
Группа: Real User Сообщений: 172 Спасибо сказали: 29 раз |
you incorrectly read a memory chip.
26.6.2014, 20:39
#85990
you need to look for the correct file only. To write down as 93S56.93C56 93S56 are read with honors
1 из 3»
Вчера, 21:15 Посл. ответ от slalex |
| Сейчас: 23.9.2026, 20:25 |
