VW PASSAT B5+ 2001 1.8T, AC compressor OFF code
 danis11
сообщение 6.8.2014, 18:47
Сообщение #87959
Спасибо сказали: 512 раза
Здравствуйте!
Имеется в разработке VW PASSAT B5+ 1.8T 2002 года. Муфта компрессора живет своей жизнью.
Ошибок нет кроме временной по температуре наружного воздуха.
В live date AC compressor OFF code стоит 8.
Напомните пожалуйста - этот код и был признак отключения муфты по наружной температуры ниже нуля, или я ошибаюсь?
Тема закрыта
Ответов (1 - 3)
 danis11
сообщение 7.8.2014, 7:21
Сообщение #87972
A/C cut-off Codes
0 = Compressor on (no shut-off requirement of the A/C compressor detected)
1 = Compressor off (refrigerant pressure was or is too high)
2 = Compressor off (blower motor circuit)
3 = Compressor off (refrigerant pressure was or is too low)
4 = Compressor off (display not currently intended)
5 = Compressor off (no engine start or no engine speed detected)
6 = Compressor off (A/C system switched off, ECON-mode activated)
7 = Compressor off (A/C system switched off, blower switch in position 0)
8 = Compressor off (outside temperature was less than 1.5°C and is still less than 2.5 °C)
9 = Compressor off (display not currently intended)
10 = Compressor off (Low voltage)
11 = Compressor off (display not currently intended)
12 = Compressor off (shut-off request from Engine Control Module (ECM) via CAN)
13 = Compressor off (voltage supply terminal 30 too high)
14 = Compressor off (Evaporator Temperature)
15 = Compressor off (display not currently intended)
16 = Compressor off (activation A/C Compressor Regulator Valve -N280- implausible)
17 = Compressor off (no signal or implausible signal from High Pressure Sensor -G65-)
18 = Compressor off (engine speed too high at standstill)
19 = Compressor off (shutoff request from Vehicle Electrical System Control Module via CAN)
20 = Compressor off (refrigerant loss-currently V8 Touareg only)
21 = Compressor off (Outside Temp < 2 degrees C, without recirc mode on)
22 = Compressor off (Outside Temp < 2 degrees C, Inside Temp. < 10 degrees C)
Тема закрыта....
P.s. Зае...., третья тема и тихо сам собой разговариваю...
А где кнопка СПАСИБО у меня!!!!!!!!
Дебилизм.........
Отредактированно danis11 - 7.8.2014, 7:29
 Zmeiarm
сообщение 7.8.2014, 10:25
Сообщение #87986
Любопытный
Спасибо сказали: 1244 раза
в своих сообщениях ты не увидишь кнопку спасибо, чтоб сам севе не по нажимал :super_smilies_001:
она появляется для тебя только в чужих сообщениях.
молодец что сам докапываешься до решения проблем.
а молчать может потому что не знают , наверно :super_smilies_005:
 danis11
сообщение 7.8.2014, 12:16
Сообщение #87996
Я про кнопку СПАСИБО знаю и понимаю.... Я смысл ее не понимаю и не пойму..... На общее обозрение...
Все, тема закрыта....
Тема закрыта
  Сейчас: 13.11.2026, 13:56
