6.8.2014, 18:47
#87959
Здравствуйте!
Имеется в разработке VW PASSAT B5+ 1.8T 2002 года. Муфта компрессора живет своей жизнью. Ошибок нет кроме временной по температуре наружного воздуха. В live date AC compressor OFF code стоит 8. Напомните пожалуйста - этот код и был признак отключения муфты по наружной температуры ниже нуля, или я ошибаюсь? |
7.8.2014, 7:21
#87972
A/C cut-off Codes
0 = Compressor on (no shut-off requirement of the A/C compressor detected) 1 = Compressor off (refrigerant pressure was or is too high) 2 = Compressor off (blower motor circuit) 3 = Compressor off (refrigerant pressure was or is too low) 4 = Compressor off (display not currently intended) 5 = Compressor off (no engine start or no engine speed detected) 6 = Compressor off (A/C system switched off, ECON-mode activated) 7 = Compressor off (A/C system switched off, blower switch in position 0) 8 = Compressor off (outside temperature was less than 1.5°C and is still less than 2.5 °C) 9 = Compressor off (display not currently intended) 10 = Compressor off (Low voltage) 11 = Compressor off (display not currently intended) 12 = Compressor off (shut-off request from Engine Control Module (ECM) via CAN) 13 = Compressor off (voltage supply terminal 30 too high) 14 = Compressor off (Evaporator Temperature) 15 = Compressor off (display not currently intended) 16 = Compressor off (activation A/C Compressor Regulator Valve -N280- implausible) 17 = Compressor off (no signal or implausible signal from High Pressure Sensor -G65-) 18 = Compressor off (engine speed too high at standstill) 19 = Compressor off (shutoff request from Vehicle Electrical System Control Module via CAN) 20 = Compressor off (refrigerant loss-currently V8 Touareg only) 21 = Compressor off (Outside Temp < 2 degrees C, without recirc mode on) 22 = Compressor off (Outside Temp < 2 degrees C, Inside Temp. < 10 degrees C) Тема закрыта.... P.s. Зае...., третья тема и тихо сам собой разговариваю... А где кнопка СПАСИБО у меня!!!!!!!! Дебилизм......... Отредактированно danis11 - 7.8.2014, 7:29
7.8.2014, 10:25
#87986
в своих сообщениях ты не увидишь кнопку спасибо, чтоб сам севе не по нажимал
она появляется для тебя только в чужих сообщениях. молодец что сам докапываешься до решения проблем. а молчать может потому что не знают , наверно |
7.8.2014, 12:16
#87996
Я про кнопку СПАСИБО знаю и понимаю.... Я смысл ее не понимаю и не пойму..... На общее обозрение...
Все, тема закрыта.... |
Вчера, 15:16 Посл. ответ от Денис |
| Сейчас: 20.9.2026, 5:41 |
