Peugeot BSI , (Body System Interface) Reboot Procedure PSA
 Zmeiarm
сообщение 5.6.2014, 10:40
Сообщение #84759
Любопытный
Спасибо сказали: 1242 раза
BSI (Body System Interface) Reboot Procedure
PROCEDURE FOR BATTERY DISCONNECTION
Whenever a vehicle battery has to be disconnected, switch off all equipment, interior lights etc,
close the doors leaving the drivers window open.
Switch off the ignition and remove the key and any diagnostic equipment.
Wait a full 3 minutes before disconnecting the battery.
The BSi must be allowed to go to SLEEP i.e. into "active economy mode". Do not operate any
equipment on the vehicle during this time. Remember, even opening the bonnet
will wake the BSi on a vehicle fitted with alarm.
If the battery is under the bonnet, open the bonnet first and leave it up.
ALWAYS disconnect any diagnostic equipment and do not operate any other vehicles during the 3
minute waiting period.
PROCEDURE FOR BATTERY RECONNECTION
Unless otherwise instructed by Peugeot or Product Service, you must always carry out the
following procedure, often referred to as a "soft re-boot", to minimize the
possibility of the BSi corrupting its own software when reconnecting the vehicles battery supply.
Ensure the procedure for battery disconnection has been adhered to and importantly all BSi
functions were switched off with the drivers window left down.
1 Close all doors
2 Remove ignition key if left in ignition
3 Reconnect battery. DO NOT open any doors
4 Wait 10 seconds
5 Switch on headlights through the driver’s window
6 Switch on ignition then start the vehicle and check system functions
Отредактированно zmeiarm - 5.6.2014, 15:17
Ответов (1 - 2)
 UgDen
сообщение 5.6.2014, 15:13
Сообщение #84773
Группа: Модератор
Спасибо сказали: 136 раз
Надо в заголовке темы написать для какой марки машины это. А то только из тела сообщения понятно, что это про Пежо речь.
 Zmeiarm
сообщение 5.6.2014, 15:18
Сообщение #84775
Любопытный
исправил
  Сейчас: 23.10.2026, 21:37
