2.8.2025, 20:13
#292168
Группа: Участник Сообщений: 11 Спасибо сказали: 1 раз |
hi all. ive got toyota yaris 1.4 diesel, engine 1nd-tv, model 2009 nlp-90. after ign on there is no any power on ecu (edc17cp07) i tryied to find any info where to find ecu relay or fuse. next to engine all fuses ok, behind glovebox as well all good. the black wire which should be powered 12v is no work after ign on. the wires nbr 42, 1, 61, 81 should be powered after ign on, no one got power. so where is main relay or fuse for the ecu??
Сегодня, 10:05 Посл. ответ от Алексей |
Сегодня, 0:49 Посл. ответ от Xor |
Вчера, 15:47 Посл. ответ от Vasilich |
13.8.2026, 14:36 Посл. ответ от Рустам |
| Сейчас: 16.8.2026, 13:11 |
