7.12.2009, 23:21
#28952
Группа: Real User Сообщений: 508 Спасибо сказали: 21 раз |
Вариант из мануала Т-300 и из автодаты для ниссанов:
Ensure all the doors have been unlocked, either by using a good transponder key or remote control plip key. Procedure 1. Turn the ignition switch from Position 0 to ON 6 times within 10 seconds. 2. Then turn ignition switch to OFF position. Leave key in ignition switch. 3. After 2 seconds, the system will enter programming mode and will flash the warning lights twice. 4. Press and HOLD the unlock button on the Plip. 5. While pressing the unlock button, press the lock button 3 times. 6. Release the unlock button. 7. The warning lights will flash once to indicate successful programming. 8. Repeat procedure 4 to 7 for up to 4 plip key’s. 9. When completed turn ignition ON, and the warning lights will flash 2 times. 10. Remove key, and check all plip key’s for operation. NOTE : The programming mode will stop when either the ignition is switch ON, 4 plip keys have been programmed or no input signal either from the switch or plip keys has been received for 120 seconds. В моём варианте не проходит, на брелке нет ни каких светодиодов. Как обучить брелок? |
| Сейчас: 15.11.2026, 9:40 |
