EEPROM crc info ,error in the BMW CAS after odometer adjustment
 votkarel
сообщение 15.3.2012, 17:50
Сообщение #63710
Heloo, there is an hidden error in the BMW CAS 1, 2 ,3 , named Eeprom crc info ( cheksum wrong)
This can be seen only using INPA ,using read IM error ( F3 function in my picture) .
I have seen this error since many years on lots of BMW-s.
This means the CAS odometer was adjusted via 9s12 ISP programming . ( Rosfar, Xprog, or other tools)
I havent found yet the solution to fix the eprom cheksum .
I reprogrammed the cas using Winkfp, Progmann, but this hidden error still is on.
I tested changing odometer in some CAS 2 using ENIGMA TOOL of a friend, and Enigma is not damaging eeprom cas , no eeprom crc info.
But when i use my ROSFAR to change CAS odometer, o got the hidden error.
Anybody knows a hex editing or watever solution for this ?
I can read and write the eeprom content to the cas anytime. but dont know how to fix it.
I think the great russian BMW tool from AVTOTOOLS can doit via obd, but I cant afford it for the moment.
Ответов (1 - 2)
 votkarel
сообщение 15.3.2012, 18:02
Сообщение #63711
here is the picture of the crc info
Отредактированно votkarel - 15.3.2012, 18:03
 dew
сообщение 16.3.2012, 9:55
Сообщение #63731
машина заводиться ? винкпфт не сможет решить эту проблему.он переливает флешь. попробуй прогманом.
  Сейчас: 14.10.2026, 20:53
