#95257
![]() Группа: Пользователи Сообщений: 5 Спасибо сказали: 0 раз ![]() |
Hi to all
my ETL hc08 programmer seams to be not working at all it's always give me error like PTA 0 must be in high state and i need to fix't but and don't know how pleaz i need help regards |
#95266
PTA 0 must be in high state This gap. Pin on the processor are not burned? Checked vias on the board or on board programming adapter have contact? |
#95349
This gap. Pin on the processor are not burned? Checked vias on the board or on board programming adapter have contact? i have tested more than 4 mcu and i have the same error everytime thanks m8 what do u think ???? ![]() |
#95353
what do u think ???? I think the bad adapter. I had the same thing. The problem in via pad on board adapter. |
#95385
I think the bad adapter. I had the same thing. The problem in via pad on board adapter. ok i well order a new adapter regards thanks alot m8 |
#95386
ok i well order a new adapter You first try on the board to ring track multimeter... |
#100208
Hi again
i have changed the adapter white a new one tested of corse and still not working, plz do you have any idea about mt probleme regards ![]() |
#100210
Your ETL HC08 is defective..
![]() You have an original device? |
#100257
Your ETL HC08 is defective.. ![]() You have an original device? i have a clone device regards |
Вчера, 18:49 Посл. ответ от Олег |
Вчера, 18:48 Посл. ответ от Олег |
Вчера, 17:36 Посл. ответ от Vasilich |
18.6.2024, 21:28 Посл. ответ от Reanimotor |
18.6.2024, 21:07 Посл. ответ от Reanimotor |
Сейчас: 20.6.2024, 15:19 |
