27.12.2014, 6:08
#95257
Hi to all
my ETL hc08 programmer seams to be not working at all it's always give me error like PTA 0 must be in high state and i need to fix't but and don't know how pleaz i need help regards |
27.12.2014, 12:18
#95266
PTA 0 must be in high state This gap. Pin on the processor are not burned? Checked vias on the board or on board programming adapter have contact? |
27.12.2014, 23:44
#95349
This gap. Pin on the processor are not burned? Checked vias on the board or on board programming adapter have contact? i have tested more than 4 mcu and i have the same error everytime thanks m8 what do u think ???? |
28.12.2014, 0:06
#95353
what do u think ???? I think the bad adapter. I had the same thing. The problem in via pad on board adapter. |
28.12.2014, 3:12
#95385
I think the bad adapter. I had the same thing. The problem in via pad on board adapter. ok i well order a new adapter regards thanks alot m8 |
28.12.2014, 3:37
#95386
ok i well order a new adapter You first try on the board to ring track multimeter... |
8.3.2015, 22:51
#100208
Hi again
i have changed the adapter white a new one tested of corse and still not working, plz do you have any idea about mt probleme regards |
8.3.2015, 22:56
#100210
Your ETL HC08 is defective..
You have an original device? |
9.3.2015, 17:15
#100257
Your ETL HC08 is defective.. You have an original device? i have a clone device regards |
| Сейчас: 6.10.2026, 0:57 |
