9.10.2013, 19:32
#73279
Группа: Пользователи Сообщений: 8 Спасибо сказали: 1 раз |
Hi all,
I need your help for read the file Dashboard Volvo V70 9472525 69294-300T ZC443002CPU 1H56A I have UPA and Carprog, but I could not read the processor. I think the problem is in the security byte, can someone help me? Greetings -------------------- Greetings,
rochinha75 |
9.10.2013, 20:19
#73281
Группа: Real User Сообщений: 305 Спасибо сказали: 16 раз |
Hi all, I need your help for read the file Dashboard Volvo V70 9472525 69294-300T ZC443002CPU 1H56A I have UPA and Carprog, but I could not read the processor. I think the problem is in the security byte, can someone help me? Greetings UPA - it s yor help ! CPU- 68HC08AZ32 Millage- 0100: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0110: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0120: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0130: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0140: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0150: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0160: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0170: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0180: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0190: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01A0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01B0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E FF FF 01C0: FF FF FF FF good luck Отредактированно andrei63 - 9.10.2013, 20:23
9.10.2013, 22:14
#73282
Hi all, Hablas Español ? Si hablas, escribeme en personal. Alomejor puedo ayudarte. Saludos, Portugal.
I need your help for read the file Dashboard Volvo V70 9472525 69294-300T ZC443002CPU 1H56A I have UPA and Carprog, but I could not read the processor. I think the problem is in the security byte, can someone help me? Greetings |
9.10.2013, 22:45
#73284
UPA - it s yor help ! CPU- 68HC08AZ32 Millage- 0100: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0110: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0120: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0130: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0140: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0150: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0160: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0170: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0180: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0190: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01A0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01B0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E FF FF 01C0: FF FF FF FF good luck I've tried, the problem is that it gives me error in Reading I think it will be necessary security byte for read... -------------------- Greetings,
rochinha75 |
9.10.2013, 23:11
#73285
UPA - it s yor help ! Дружище, я не профи в Английском, но понял, что он не может своими прогерами прочитать проц, так-как он закрыт и нужно вводить Сек-бит. Чел просит список возможных Сек-битов на этот проц. Если кто имеет, подкиньте. Только-что он написал мне в личку, но по испански тоже не говорит- использует переводчик гугля. Был-бы не в Порто, а в Барсе, я б ему прочитал Оранжем, а так только надежда на вас, господа.
CPU- 68HC08AZ32 Millage- 0100: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0110: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0120: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0130: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0140: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0150: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0160: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0170: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0180: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0190: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01A0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 01B0: 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E 0E FF FF 01C0: FF FF FF FF good luck |
12.10.2013, 11:00
#73316
Master Группа: Real User Сообщений: 486 Спасибо сказали: 9 раз |
Hi all, I need your help for read the file Dashboard Volvo V70 9472525 69294-300T ZC443002CPU 1H56A I have UPA and Carprog, but I could not read the processor. I think the problem is in the security byte, can someone help me? Greetings I can help you if you post picture of your connection here. Hint: problem is not in security bytes! |
12.10.2013, 11:58
#73317
I can help you if you post picture of your connection here. Hint: problem is not in security bytes! these are my connections Прикрепленные файлы
rochinha75 |
12.10.2013, 12:05
#73318
these are my connections Upa pin 6 to both mcu pin 96,97. Pin 8 unused. Lift irq. If you post picture of volvo pcb it would be easier to help |
12.10.2013, 12:33
#73319
rochinha75 |
12.10.2013, 12:39
#73320
Lift 7 pin of hc729, connect upa pin 6 to pin 96,97, another pins like in manual. choose autodetect baud rate in upa... And read it ;)
14.10.2013, 22:56
#73368
Lift 7 pin of hc729, connect upa pin 6 to pin 96,97, another pins like in manual. choose autodetect baud rate in upa... And read it ;) Thanks For your help, but unfortunately did not work. I've tried numerous ways and can not read... -------------------- Greetings,
rochinha75 |
15.10.2013, 13:02
#73373
Thanks For your help, but unfortunately did not work. Entonces tenias la razon. El problema esta en security byte. Yo me encontraba con el mismo problema hasta que compré el Orange. El UPA puedes conectar de cualquier manera, pero no conseguirás leer un microcontrolador, si esta cerrado con sec-byt. Es que el mismo microcontrolador puede estar cerrado, o abierto (sin sec-byt).
I've tried numerous ways and can not read... |
15.10.2013, 13:09
#73374
Entonces tenias la razon. El problema esta en security byte. Yo me encontraba con el mismo problema hasta que compré el Orange. El UPA puedes conectar de cualquier manera, pero no conseguirás leer un microcontrolador, si esta cerrado con sec-byt. Es que el mismo microcontrolador puede estar cerrado, o abierto (sin sec-byt). hola, gracias por su respuesta. Por cierto, me puede decir donde usted compra su programador. Estoy dividido entre Orange 5 y ETL -------------------------------------------------------------------------------------------------------------------- hello, thanks for your reply. By the way, can you tell me where you purchase your programmer. I'm torn between Orange 5 and ETL -------------------- Greetings,
rochinha75 |
15.10.2013, 14:19
#73375
Группа: Real User Сообщений: 68 Спасибо сказали: 1 раз |
если упа ,то выпаивать и в адаптер.на плате может не получиться.насчет защиты сомнительно.лично еще мне az32 не попадались.на плате и омега не брала,тоже только в адаптере.а вот multilinc hc08 делает.это из моего скромненького опыта.может и не прав где.
Отредактированно elektrik72 - 15.10.2013, 14:31
15.10.2013, 14:34
#73377
если упа ,то выпаивать и в адаптер.на плате может не получиться.насчет защиты сомнительно.лично еще мне az32 не попадались.на плате и омега не брала,тоже только в адаптере.а вот multilinc hc08 делает.это из моего скромненького опыта.может и не прав где. Спасибо за вашу помощь, Этот процессор QFP100. Я постараюсь с ETL, ETL'll купить клон, надеюсь, что он работает. Я не могу читать с УПА или XPROG -------------------- Greetings,
rochinha75 |
8.5.2024, 17:14 Посл. ответ от Geryy |
8.5.2024, 15:46 Посл. ответ от max |
6.5.2024, 13:29 Посл. ответ от Алексей |
6.5.2024, 12:58 Посл. ответ от Алексей |
Сейчас: 10.5.2024, 15:53 |
