25.10.2018, 5:29
#264143
Группа: Участник Сообщений: 5 Спасибо сказали: 0 раз |
Hello Guys
I need serious help here! SITUATION: The car was moving, owner had a flat battery, tried to jump car several times until car wrote steering lock faulty workshop no more ignition on. 1. When you insert key in ignition, ESL unlocks but no ignition on. 2. Opened ESL reset it manually to lock position, repeat scene No. 1 Unlocks no ignition on. 3. Tried to scan car using FVDI ecu appears for 3 sec then disappears, cleared faults only in BCM2 still no ignition on. 4. Bought used ESL from an unknown car but same part numbers, tried to adpat using VVDi2 failed 5. Swapped ESL MCU same thing. 6. Stuck!!!! 7. If i remove key ELS/ELV does not Lock back Tools i have: VVDI2 (Full) VVDI Prog, FLY FVDI, XTOOL X100, SuperVag (ORG) The Car Details: VIN=WVGZZZ7PZBD010837 CS=241F5D90C83EBB0EE48DB41DC91F67E1 POWER_CLASS=FE IMMO_STATUS=1###0:Not Learned(Virgin), 1:Learned KEY_COUNT=2 KEY_1=57801497 KEY_2=508F1497 KEY_3=FFFFFFFF KEY_4=FFFFFFFF KEY_5=FFFFFFFF KEY_6=FFFFFFFF KEY_7=FFFFFFFF KEY_8=FFFFFFFF Have attached All dump files, if anyone can Repair BCM2 dumps or Sync new ELV or Disable ELV in BCM2 or give me a procedure to start the car will be helpful. regards |
| Сейчас: 22.11.2026, 15:24 |
