2010 VW TOUREG BCM2 Repair OR SYCNCHRO
 chizz85
сообщение 25.10.2018, 5:29
Сообщение #264143
Hello Guys
I need serious help here!
SITUATION:
The car was moving, owner had a flat battery, tried to jump car several times until car wrote steering lock faulty workshop no more ignition on.
1. When you insert key in ignition, ESL unlocks but no ignition on.
2. Opened ESL reset it manually to lock position, repeat scene No. 1 Unlocks no ignition on.
3. Tried to scan car using FVDI ecu appears for 3 sec then disappears, cleared faults only in BCM2 still no ignition on.
4. Bought used ESL from an unknown car but same part numbers, tried to adpat using VVDi2 failed
5. Swapped ESL MCU same thing.
6. Stuck!!!!
7. If i remove key ELS/ELV does not Lock back
Tools i have: VVDI2 (Full) VVDI Prog, FLY FVDI, XTOOL X100, SuperVag (ORG)
The Car Details:
VIN=WVGZZZ7PZBD010837
CS=241F5D90C83EBB0EE48DB41DC91F67E1
POWER_CLASS=FE
IMMO_STATUS=1###0:Not Learned(Virgin), 1:Learned
KEY_COUNT=2
KEY_1=57801497
KEY_2=508F1497
KEY_3=FFFFFFFF
KEY_4=FFFFFFFF
KEY_5=FFFFFFFF
KEY_6=FFFFFFFF
KEY_7=FFFFFFFF
KEY_8=FFFFFFFF
Have attached All dump files, if anyone can Repair BCM2 dumps or Sync new ELV or Disable ELV in BCM2 or give me a procedure to start the car will be helpful.
regards
Прикрепленный файл  TOUREG_FILES__BCM2_ECU_ESL_2.zip ( 1.38 MB )
  Сейчас: 9.11.2026, 23:11
