17.10.2010, 23:57
#46048
hello to all and from u8n Pò of time that does not work more mine upa it says me always programmer not found a 1001 ce friend who helps me to resolve the problem
18.10.2010, 9:24
#46056
1) reboot comp
2) update driver 3) check fuse 4) write to Penko with test USB (if pass test). Penko will sent patch for you. -------------------- http://speedometrs35.ru (ツ)
19.10.2010, 21:37
#46140
hello,
test hardware help me 5V Tests. Close J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V Test Failed --------------------------------------------------------------------------------------------------------------- Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V Test Failed --------------------------------------------------------------------------------------------------------------- Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V Test Failed --------------------------------------------------------------------------------------------------------------- Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V Test Failed --------------------------------------------------------------------------------------------------------------- 3.3V Tests. Open J1 and press a key to continue --------------------------------------------------------------------------------------------------------------- Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V Test Failed --------------------------------------------------------------------------------------------------------------- Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V Test Failed --------------------------------------------------------------------------------------------------------------- Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V Test Failed --------------------------------------------------------------------------------------------------------------- Test60 Test Failed --------------------------------------------------------------------------------------------------------------- 14 Tests failed |
| Сейчас: 24.11.2026, 7:54 |
