11.4.2014, 20:31
#81790
Группа: Модератор Сообщений: 462 Спасибо сказали: 327 раз |
Electronic Service Manual 2008
FWD - Index ACC - Accelerator Control System ADP - Automatic Drive Positioner AV - Audio, Visual & Navigation System BCS - Body Control System BR - Brake System BRC - Brake Control System BRM - Body Repair CHG - Charging System CL - Clutch CO - Engine Cooling System DEF - Defogger DLK - Door & Lock DLN - Driveline EC - Engine Control System EM - Engine Mechanical EX - Exhaust System EXL - Exterior Lighting System EXT - Exterior FAX - Front Axle FL - Fuel System FSU - Front Suspension GI - General Information GW - Glass & Window System HA - Heater & Air Conditioning System HAC - Heater & Air Conditioning Control System HBB - Hybrid Battery System HBR - Hybrid Brake System HRN - Horn INL - Interior Lighting System INT - Interior IP - Instrument Panel LAN - LAN System LU - Engine Lubrication System MA - Maintenance MIR - Mirrors MWI - Meter, Warning Lamp & Indicator PB - Parking Brake System PCS - Power Control System PG - Power Supply, Ground & Circuit Elements PWC - Power Window Control System PWO - Power Outlet RAX - Rear Axle RF - Roof RSU - Rear Suspension SB - Seat Belt SBC - Seat Belt Control System SCS - Suspension Control System SE - Seat SEC - Security Control System SN - Sonar System SR - SRS Airbag SRC - SRS Airbag Control System ST - Steering System STC - Steering Control System STR - Starting System TM - Transaxle & Transmission VTL - Ventilation System WCS - Warning Chime System WT - Road Wheels & Tires WW - Wiper & Washer Прикрепленные файлы
3.12.2017, 12:23
#253603
Группа: Real User Сообщений: 2174 Спасибо сказали: 501 раз |
NISSAN X-TRAIL, model T32 series (T32; 2013–present). This manual contains maintenance and repair procedures.
Index - Manual - Отредактированно danis11 - 3.12.2017, 12:32
2.7.2018, 15:35
#261625
Группа: Real User Сообщений: 781 Спасибо сказали: 53 раза |
Парни, есть мануал на Nissan Wingroad HR15DE 2010 год ?
Отредактированно SOleg - 2.7.2018, 15:39
12.7.2018, 17:22
#261813
Группа: Участник Сообщений: 39 Спасибо сказали: 19 раз |
Nissan Juke 2010 бензиновые ДВС HR16DE,MR16DDT (изд. Третий Рим)
Отредактированно Elder - 12.7.2018, 17:32
16.7.2018, 8:59
#261850
Доброго времени суток!
Прошу помощи,нужны схемы на автомобиль Nissan Rogue 2015 года,вроде как называют дорестайловым (-08.15) Зараннее благодарю. |
13.10.2019, 8:41
#274435
Nissan Rogue 2016 Service Repair Manual EN
GENERAL INFORMATION GENERAL INFORMATION ENGINE ENGINE LUBRICATION SYSTEM ENGINE COOLING SYSTEM ENGINE CONTROL SYSTEM FUEL SYSTEM STARTING SYSTEM EXHAUST SYSTEM ACCELERATOR CONTROL SYSTEM TRANSMISSION & DRIVELINE TRANSAXLE & TRANSMISSION FRONT AXLE REAR AXLE DRIVELINE SUSPENSION FRONT SUSPENSION REAR SUSPENSION ROAD WHEELS & TIRES BRAKE BRAKE SYSTEM PARKING BRAKE SYSTEM BRAKE CONTROL SYSTEM STEERING STEERING SYSTEM STEERING CONTROL SYSTEM RESTRAINTS SEAT BELT SRS AIRBAG SRS AIRBAG CONTROL SYSTEM VENTILATION, HEATER & AIR CONDITIONER VENTILATION SYSTEM HEATER & AIR CONDITIONING SYSTEM HEATER & AIR CONDITIONING CONTROL SYSTEM BODY INTERIOR INTERIOR INSTRUMENT PANEL SEAT BODY EXTERIOR, DOORS, ROOF & VEHICLE SECURITY DOOR & LOCK SECURITY CONTROL SYSTEM GLASS & WINDOW SYSTEM POWER WINDOW CONTROL SYSTEM EXTERIOR BODY REPAIR ROOF DRIVER CONTROLS MIRRORS EXTERIOR LIGHTING SYSTEM INTERIOR LIGHTING SYSTEM WIPER & WASHER DEFOGGER HORN ELECTRICAL & POWER CONTROL POWER OUTLET BODY CONTROL SYSTEM LAN SYSTEM POWER CONTROL SYSTEM CHARGING SYSTEM POWER SUPPLY, GROUND & CIRCUIT ELEMENTS DRIVER INFORMATION & MULTIMEDIA METER, WARNING LAMP & INDICATOR WARNING CHIME SYSTEM AUDIO, VISUAL & NAVIGATION SYSTEM CRUISE CONTROL & DRIVER ASSISTANCE CRUISE CONTROL SYSTEM DRIVE ASSISTANCE SYSTEM DRIVE MODE SYSTEM MAINTENANCE MAINTENANCE Одним файлом все Содержимое под "index". Отредактированно danis11 - 13.10.2019, 8:48
17.10.2019, 10:44
#274559
Leaf 2010 ZE0
Service manual Прикрепленные файлы
Сегодня, 23:05 Посл. ответ от Aleks91 |
Сегодня, 21:57 Посл. ответ от Reanimotor |
Сейчас: 3.6.2024, 23:40 |
