23.5.2018, 9:45
#260705
Добрый день! Нужна помощь! Машина перестала ехать! Вариатор выдаёт ошибку p188f. Не могу найти на просторах интернета...Может кто то знает что это? Помогите.
1.11.2018, 11:15
#264493
Группа: Пользователи Сообщений: 3 Спасибо сказали: 1 раз |
P188F ELECTRIC OIL PUMP (Electric Oil Pump) After the following detection condition are met during stop/start system operation, the detection condition is met again in the same DC and during 2nd or later stop/start system operation. Detection condition The line pressure is less than 0.06 MPa continuously for 10 seconds. ■ CAUTION ■ When the detection condition is met during the 1st stop/start system operation and the ignition switch is turned OFF, diagnosis starts from the beginning. Diagnosis Procedure 1.AIR BLEEDING OF ELECTRIC OIL PUMP Perform air bleeding of the electric oil pump. Work Procedure 1.PREPARATION BEFORE WORK Start the engine and warm it up. After warm-up, stop the engine and wait for 60 seconds or more. >> GO TO 2. 2.BLEED ELECTRIC OIL PUMP With CONSULT Turn ignition switch ON. ■ CAUTION ■ Never start the engine. Shift the selector lever to the P position. Select “WORK SUPPORT” in “TRANSMISSION”. Select “ELECTRIC O.P. AIR BLEEDING”. Touch “Start”. ■ CAUTION ■ Never start the engine during air bleeding. NOTE: It may take approximately 20 seconds until completion. |
25.11.2026, 9:22 Посл. ответ от ypiter |
| Сейчас: 27.11.2026, 6:03 |
