28.6.2025, 17:04
#292078
Группа: Пользователи Сообщений: 0 Спасибо сказали: 0 раз |
hi all hope you are all well i have been searching and cant find an answer if anyone is able to help i would appreciate it. i purchased a car without keys as the owner lost it, he had a key guy out to make a new key but could not find the immo box.
I am now going to remove the dash completely as i am unable to find it either. the ecu has been opened before and i can post the eeprom data thats been read but im not sure if the eeprom data is correct. no security light on the dash either. does anyone know which is E0M wire on the avensis ecu and how are the pins numbered on the ecu. thank you and appreciate all the help Прикрепленные файлы
25.11.2026, 9:22 Посл. ответ от ypiter |
| Сейчас: 27.11.2026, 7:42 |
